Aktuálny čas je Ned 25. Okt 2026 22:15:39
 Throttle 6.3.23.2009 Cracked
 Predmet príspevku: Throttle 6.3.23.2009 Cracked
PoslaťNapísal: Uto 24. Mar 2009 13:05:17
This is a tool that allows you to modify your modem settings to increase internet performance
Throttle will help you increase the internet performance. No modifications to your hardware are made and all adjustments and settings are done in an easy to use interface that a child could use.
Most 'other' modem enhancers promise that they work while you notice no difference at all in internet speed. Throttle on the other hand has been tried and tested and proven to work.
Whether you use a 14.4/28.8/33.6/56k modem, cable modem, or dsl modem, Throttle will boost your internet connection speed.
Notice also that Throttle will modify your modem settings to handle those annoying disconnections and hangup's so they happen less often.You no longer have to put up with downloading a huge file and being disconnected in the middle of the transfer.
Here are some key features of "Throttle":
· Makes direct changes to system registry and system files to enhance internet download and upload speeds.
· Automatically adjusts settings and changes made based on computer and modem specifications, complete fault tolerance system implemented.
· Compatible with all modem types - Dial-up, DSL, ADSL, Cable, ISDN, and Satellite internet connections.
· Enhances both internet transfer speeds as well as local area network speeds.
· Easy and intuitive user interface which performs all setting changes immediately.
· Microsoft Internet Explorer 4 or higher
· Intel Pentium 90 MHz or higher (P 166 MHz recommended)
· 8 Mb RAM (32 Mb recommended)
· 5 Mb hard disk space
· VGA or higher resolution monitor
· Mouse or other pointing device
Toto je nástroj který dovoluje vám modifikovat vaše nastavení modemu zvýšit internetový výkon
Průdušnice pomůže vám zvýšit internetový výkon. Žádné modifikace vašemu hardwaru jsou udělané a všechny upravení a nastavení jsou udělané v snadno použitelném rozhraní které dítěti mohlo užívat.
Největší jiní modem zvětšovačové slibují že oni pracují zatímco vy všimnete si ne ve všech rozdílu mezi internetovou rychlostí. Průdušnice na druhé straně byla osvědčená a testovaný a prokázaný k tomu, aby pracovala.
Zda vy užíváte 14.4/28.8/33.6/56k modem, kabelový modem, či dsl modem, průdušnice bude podporovat vaši internetovou rychlost spojení.
Všimněte si také Throttle bude modifikovat vaše nastavení modemu ovládat ti, kdo jste otravní odpojení a problém- ovo tak oni se stávají méně často.Vy musíte již ne déle snášeli stahování obrovského souboru a být odpojený uprostřed transferu.
Zde jsou nějaké klíčové rysy "Průdušnice":
· dělá přímé změny systémovým registru a systémovým souborům k tomu, aby zvětšily internetový download a upload chvátá.
· automaticky nastavuje nastavení a změny udělaly založený na počítačových a modemu specifikacích, kompletní systém odolnosti implementované.
· kompatibilní se všemi modemem druhy - telefonní, DSL, ADSL, kabel, ISDN, a Satellite internetová spojení.
· zvětšete obojí internetový transfer rychlost stejně jako lokální síť rychlost.
· snadné a intuitivní uživatelské rozhraní které vykonává veškeré nastavení mění ihned.
· Microsoft Internet Explorer 4 či vyšší
· Intel Pentium 90 MHZ či vyšší (P 166 MHZ doporučil)
· 8 Mb RAM (32 Mb doporučil)
· 5 Mb místo na disku
· VGA či vyšší rozlišovací monitor
· myš či jiný směřující k zařízení
