Aktuálny čas je Pia 23. Okt 2026 22:00:28
 PCHeal 1.3.23.2009 Cracked
 Predmet príspevku: PCHeal 1.3.23.2009 Cracked
PoslaťNapísal: Uto 24. Mar 2009 12:55:50
Locates and repairs problems with software and hardware incompatibilities which lead to computer performance issues
PCHeal sets the standard for PC optimizing software.
PCHeal software will locate and repair problems with software and hardware incompatibilities which lead to computer performance issues.
PCHeal is very easy to use, fully compliant with all versions of Microsoft Windows and adjusts itself to your computer specifications. Take your existing PC and revitalize it the easy way.
PCHeal makes direct changes to system registry and system files to enhance memory, screen drawing, animations, refresh rates, cpu threading speeds.
PCHeal automatically adjusts settings and changes made based on computer specifications, complete fault tolerance system implemented.
Deep system analyzer and diagnostic features which attempt to find and repair any potential problems with the computer affecting its performance.
Here are some key features of "PCHeal":
· Advanced software based over-clocking features to enhance memory and cpu priorities.
· Easy and intuitive user interface which performs all setting changes immediately.
· Try before you buy licensing with FREE lifetime upgrades and quality technical support.
· Microsoft Internet Explorer 4 or higher
· Intel Pentium 90 MHz or higher
· 8 Mb RAM (32 Mb recommended)
· 5 Mb hard disk space
· VGA or higher resolution monitor
· Mouse or other pointing device
Lokalizuje a opravuje problémy se softwarovými a hardwarem neslučitelnostmi které vést k počítačovým výkonovým problémům
PCHEAL nastavuje standard pro PC optimalizující software.
PCHEAL software bude lokalizovat a opravit problémy se softwarovými a hardwarem neslučitelnostmi které vést k počítačovým výkonovým problémům.
PCHEAL je velmi snadno použitelný, plně vyhovující se všemi verzemi Microsoft Windows a nastavuje sám vašim počítačovým specifikacím. Vezměte váš existující PC a revitalizovte to snadno.
PCHEAL dělá přímé změny systémovým registru a systémovým souborům k tomu, aby zvětšily paměť, obrazovku kresbu, animace, obnovovací kmitočty, cpu proplétající se rychlost.
PCHEAL automaticky nastavuje nastavení a změny udělaly založený na počítačových specifikacích, kompletní systém odolnosti implementované.
Hluboké systémové analyzátor a diagnostické znaky který pokusí se o najít a opravit nějaké /každé /žádné potenciální problémy s počítačem ovlivněním jeho výkonu.
Zde jsou nějaké klíčové rysy "PCHEAL":
· Pokročilý softwarový založený přílišný-časoměrný uvádí zvětšit paměť a cpe priority.
· snadné a intuitivní uživatelské rozhraní které vykonává veškeré nastavení mění ihned.
· zkouška předtím než vy koupíte licencování s FREE celoživotní aktualizacemi a kvalitní technickou podporou.
· Microsoft Internet Explorer 4 či vyšší
· Intel Pentium 90 MHZ či vyšší
· 8 Mb RAM (32 Mb doporučil)
· 5 Mb místo na disku
· VGA či vyšší rozlišovací monitor
· myš či jiný směřující k zařízení
