Aktuálny čas je Štv 22. Okt 2026 2:40:25
 Translator-NeoDic 1.1
 Predmet príspevku: Translator-NeoDic 1.1
PoslaťNapísal: Štv 12. Mar 2009 10:38:55
NeoDic - dictionary of context transfer. Context transfer enables simply by pointing your cursor over the unfamiliar word or phrase that instantly receive its translation. This type of transfer is very convenient for reading Web pages, reading the help system, communicating in chat, text layout.
Among other things NeoDic has the following features:
Allows viewing of different formats, and dictionaries of all languages;
It has a large number of options which make it possible to configure the application to your liking:
opportunity to appoint «shortcuts» for comfortable control program;
change event when clicking the left and right-click on the icon in the notification area;
change the delay before the advent of tips;
show only a hint, while keeping the specified key;
change the form of hints (rectangular or Balloon);
change the location of the cursor hints about how it is convenient to the user;
to establish a shadow under the tip, as well as its background color and text;
change the settings window for viewing the dictionary, as well as change the general options NeoDic;
It has a full reference system;
Stable running Windows 2000/2003/XP/Vista;
It occupies little memory;
Has multilingual interface.
What's new:
+ Added a new language (Ukrainian);
+ Added the ability to change color tips, as well as windows dictionary;
+ Modified contextual translation;
+ Fixed interface;
+ Added thanks to the "About";
+ Fixed minor bugs.
v1.0.1 (10.12.08)
+ Added the ability to zoom window dictionary and a window of options for comfortable use NeoDic;
+ Fixed bug - when you install the new version over the old settings are saved now;
+ Change the look of the window "Thanks";
+ Fixed bug in option "Display a message" Word ... not found in the dictionary "- now works;
+ Fixed a bug with the CPU load when using the option "Show hint only when you click ...";
+ Fixed minor bugs.
v1.1 (09.02.08)
+ Now you can use dozens of dictionaries, in particular formats and sdict dic;
+ Directly from NeoDic possible to navigate to a resource in the Internet, where a number of dictionaries;
+ Added option to view information about the dictionary;
+ Now when you start NeoDic remembers and automatically activates the previously selected dictionary;
+ Fixed a bug that has not saved the settings NeoDic to complete Windows;
+ Fixed bug that prevented NeoDic run in Windows 2000;
+ Fixed bug due to which the Windows Server 2003 does not work contextual translation;
+ After the inclusion of the contextual translation of "hot key", if the cursor over a word, the tooltip appears instantly no need to remove the mouse cursor.
NeoDic - slovník transferu souvislosti. transfer souvislosti umožňuje jednoduše ukazováním vaším kurzorem přes neznámé slovo nebo fráze který okamžitě přijmout jeho překlad. Tento typ transferu je velmi vhodný pro čtecí webové stránky, čtení systému nápovědy, komunikace v povídání, textové rozvržení.
Kromě jiného NeoDic má následující rysy:
Dovoluje pohled na odlišné formáty, a slovníky všech jazyků;
To má velké množství voleb které umožňuje konfigurovat aplikaci vaší zálibě:
příležitost k tomu, aby stanovila « zkratky » pro pohodlný řídicí program;
změnit událost při kliknutí odejít a kliknutí na pravou klávesu na ikoně v oznamovací oblasti;
změnit zpoždění před příchodem tipů;
ukázat jen narážku, při držení specifikovaného klíče;
změnit formu radů (pravoúhlý či Balloon);
změnit umístění kurzorových radů o tom jak to je blízko uživatel;
ustanovit stín pod tipem, stejně jako jeho barva pozadí a text;
změnit nastavení okno pro prohlížení slovník, stejně jako mění hlavní volby NeoDic;
To má plný srovnávací soubor;
Stabilní běžící Windows 2000/2003/XP/Vista;
To zabírá malou paměť;
Mějte mnohojazyčné rozhraní.
Co je nového:
+ přidaný nový jazyk (Ukrajinec);
+ přidaná schopnost k tomu, aby měnila barevné tipy, stejně jako okna slovník;
+ upravený kontextový překlad;
+ fixované rozhraní;
+ přidané díky "O";
+ fixované menší hmyz.
v1.0.1 (10.12.08)
+ přidaná schopnost k tomu, aby zvětšila okenní slovník a okno voleb pro pohodlný užívá NeoDic;
+ fixovaná štěnice - kdy vy instalujete novou verzi přes stará nastavení jsou ušetření právě teď;
+ měňte vzhled okna "Díky";
+ fixovaná štěnice ve volbě "Zobrazte zprávu" Slovo ... ne nalezený v slovníku "- nyní pracuje;
+ soustava štěnice s CPU naloží při používání volby "Ukázat narážce jen když vy cvaknete ...";
v1.1 (09.02.08)
+ nyní vy můžete použít tucty slovníky, zvláště formáty a sdict dic;
+ přímo z NeoDic možné navigovat k zdroji v Internetu, kde řada slovníků;
+ přidaná volba k tomu, aby dívala se na informaci o slovníku;
+ právě teď kdy vy začnete NeoDic si pamatuje a automaticky aktivuje předtím vybraný slovník;
+ soustava štěnice která neušetřila nastavení NeoDic kompletním Windows;
+ fixovaná štěnice která předešla NeoDic běží ve Windows 2000;
+ fixovaná štěnice kvůli které windowsovský Server 2003 nepracuje kontextový překlad;
+ po zahrnutí kontextového překladu "klávesová zkratka", jestli kurzor přes slovo, tooltip se jeví okamžitě není třeba odstranit myš kurzor.
 Predmet príspevku: Re: Translator-NeoDic 1.1
PoslaťNapísal: Uto 03. Nov 2009 15:54:58
