Aktuálny čas je Sob 24. Okt 2026 22:10:54
 Long Range Shooting 2 - Stante sa profesionálnymi strelcami
 Predmet príspevku: Long Range Shooting 2 - Stante sa profesionálnymi strelcami
PoslaťNapísal: Uto 10. Mar 2009 10:39:29
The popular long-range shooting, mil dot ranging training simulation. On CD for PC's or Mac's. Realistic controls, including a 20 power zoom, sound effects and scenery make this a simulation as close as you can get to field practice at home on your computer. All without wasting a single round of ammunition.
Nothing else like it
Three calibers. Along with the standard .308, 175 grain, also practice with a Windrunner .338 and 50 caliber. The
calculations for the .338 are based on a 250 grain bullet loaded and recommended by Black Hills Ammunition. Knock down
targets out to 2000 yards with a 50 caliber Windrunner.
Mil Dot Ranging
Practice Mil Dot ranging on three target sizes. A 12" X 12" swinging plate, a 30" X 18" knock down plate and a
regulation 72" X 19" knock down plate. Each caliber has 70 different range exercises, plus an advanced stage for each
caliber with 25 different timed hold-offs and moving targets.
Add in different atmospheric extremes and you get almost 300 different ranging scenarios.
Not a game
This a training simulation. The result of each shot is exactly calculated to show where the bullet hits on the target.
This simulation graphically displays how wind, altitude, and temperature affect the bullet in flight. The results for
distance are given in both meters and yards.
Bonus Stages
The CD has five bonus stages. There are two .308 stages, one with a 168 grain bullet and one 190 grain out of a 300
WinMag. In addition, there is a .223 (5.56) , a .264, and an experimental .408 based on the Chey Tac bullet. Each bonus
range has ten stages and three different target sizes.
Interactive Classrooms
Learn how to mil dot range, scope the wind, how to use a range card and engage moving targets in Classroom modules.
Every shooter should understand minute of angle and exterior ballistics. These subjects and more are also explained
with interactive tests.
Practice at home on your computer.
Three calibers
Three target sizes
Realistic interface
Over 250 stages
Expanded and improved classroom sections
Custom stage available
mds, mdf files in the archive burn them on CD or mount with DaemonTools, Alcohol 120%, MagicISo, etc...
Populární dalekonosné střílení, tisícina palce tečkují řazení výcvikovou simulaci. Na CD pro PC- ovo či Mac- ovo. Realistické ovládací prvky, včetně 20 výkonového zoom, zvuková efekty a scenérie udělá tuto simulaci tak blízký jak vy se můžete dostat do pole praxe doma na vašem počítači. Všechno bez plýtvání jednotlivým kolem střeliva.
Nic jiného jako to
Tři kalibry. Spolu se standardem .308, 175 zrno, také prakt ikuje s Windrunner .338 a 50 kalibr.
Počítat na .338 jsou založené na 250 obilní kulce naložené a doporučený od Black Hills Ammunition. Srazte
cíle ven k 2000 yardů s 50 kalibrem Windrunner.
Tisícina palce bod řazení
Cvičné Mil Dot řazení tří plánovaných velikostí. 12" X 12" houpací talíř, 30" X 18" srazit talíř a
regulaci 72" X 19" srazit talíř. Každý kalibr má 70 jiná rozsahová cvičení, plus pokročilý stupeň pro každý
kalibr s 25 jiným časovaným držením-u a pohybujících se cílů.
Dodejte jiné atmosférické extrémy a vy dostanete téměř 300 jiný dosahující scénářů.
Ne hra
Tato výcviková simulace. Výsledek každého výstřelu je přesně vypočítaný k tomu, aby ukázal kde kulka narazí na cíl.
Tito simulace grafičtí zobrazovače jak vítr, nadmořská výška, a teplota ovlivní kulku za letu. Výsledky pro
vzdálenost jsou dané v oba metrech a dvorech.
Prémie inscenuje
CD Má pět prémií stupňů. Tam jsou dva .308 stupně, jeden s 168 obilním kulkou a jedním 190 zrnem z 300
WinMag. Navíc, tam je .223 (5.56) , .264, a experimentální .408 založený na Chey Tac kulce. Každý prémiový
rozsah má deset stupňů a tří jiných plánovaných velikostí.
Interaktivní třídy
Učte se / dozvěďte se jak tisícina palce rozsah bodu, rozsahu větru, jak použijte rozsahovou kartu a angažujte se pohyblivé terče v Classroom jednotkách.
Každý střelec by měl rozumět úhlové minutě a vnější balistice. Tyto předměty a více také jsou vysvětlené
s interaktivními testy.
Praktikujte doma na vašem počítači.
Tři kalibry
Tři plánované velikosti
Realistické rozhraní
Přes 250 stupně
Rozšířené a zlepšené sekce třídy
Uživatelský stupeň dostupný
mds, mdf soubory v archivu spálí je na CD či montovat s DaemonTools, alkoholem 120%, MagicISo, a tak dále..
 Predmet príspevku: Re: Long Range Shooting 2 - Stante sa profesionálnymi strelcami
PoslaťNapísal: Uto 27. Okt 2009 21:48:44
