Aktuálny čas je Štv 22. Okt 2026 21:26:58
Vytvoriť novú tému Odpovedať na tému  [ Príspevkov: 4 ]
 Registry Winner v4.3.2.20
 Predmet príspevku: Registry Winner v4.3.2.20
PoslaťNapísal: Str 25. Feb 2009 8:10:05
Registry Winner? is a top-ranking error-resolution registry cleaner which will fix the computer errors and optimize the system speed. Various annoying problems will gradually appear like slow speed, crashing or freezing, blue screen, deadlock, error messages etc. after your computer being used for a period of time.
Registry Winner? uses the most advanced technology to scan your hard driver and give you a comprehensive diagnosis in seconds. Once the problems have been located, Registry Winner? offers you a professional and highly-efficient solution to set your PC in a fantastic state! By using Registry Winner? regularly, your system should not only be more stable but it will also help streamline your pc registry without expensive hardware upgrades.
Registry Winner? Features and Advantages:
Registry Winner? will easily enhance, maintain and repair your pc of the following
* Check Invalid User Settings
* Check Invalid System Settings
* Check Invalid Application Paths
* Check Recently Used Files
* Check Invalid Class Keys
* Validate Active-X, OLE & COM Objects
* Check Uninstall Sections
* Check Invalid Fonts
* Runtime Errors
* DLL Errors
* Windows Startup Errors
* Internet Explorer Errors
* Java Errors
* javascript Errors
* Check Shared DLLs
* Validate Startup Programs
* Check Invalid Shortcuts
* Check Invalid File Associations
* Check Invalid Start Menu Items
* Delete Empty Registry Keys
* Checks System Services
* Blue Screen
* Driver Errors
* System Crashes
* Task Manager Related
* Most Registry Problems
* Organize Quicker Startup Programs
* Fix Report
* Auto-Backup & Full Backup
* Ignore List
* Computer Management
* Windows Update
* System Properties
* Control Panel
* Disk Defragmenter
* Disk Cleanup
* Local Security Settings
* Local Users and Groups
* Group Policy Editor
* Security Center
* Device Manager
* Event View
* Disk Management
* Performance Monitor
* Add/Remove Manager
* BHO Manager
* Internet Options
* Scheduler
* Load Windows Faster
* Run Applications Smoothly
* Regain More Disk Space
* High-performance scanning
* Automatic Updates
* Unlimited Free Technical Support
Registrační vítěz? je vysoko postavený chybový-rozlišovací registrační čistírna která upevní počítačové chyby a optimalizovat systémovou rychlost. Různé otravné problémy postupně se objeví jako pomalá rychlost, havarující či mrazivá, modrá obrazovka, mrtvý bod, zprávy o chybě a tak dále po vašem počítači je použitý pro časový interval.
Registrační vítěz? užívá nejpokročilejší technologii k tomu, aby skenovala vašeho tvrdého řidiče a dát vám komplexní diagnózu v sekundách. Jednou problémy byly lokalizované, registrační vítěz? nabízejte vám profesionála a vysoce-účinné řešení nastavit váš PC ve fantastickém stavu / státu! Použitím registračního vítěze? pravidelně, váš systém by měl nejen být víc stabilní ale to bude také pomáhat usměrnit váš procent registr bez drahých hardwaru aktualizací.
Registrační vítěz? Rysy a výhod:
Registrační vítěz? snadno zvětšit, udržovat a opravit váš procent následující
* kontrolní invalidní uživatelská nastavení
* kontrolní invalidní systémová nastavení
* kontrolní invalidní aplikační cesty
* šek nedávno užíval soubory
* kontrolní invalidní třída zaklínovává
* potvrdí činné rod-X, OLE & COM objekty
* šek odinstaluje sekce
* kontrolní invalidní fonty
* runtime chyby
* DLL Errors
* Windows startovní chyby
* Internet Explorer chyby
* Java chyby
* javascript Errors
* šek sdílel DLLS
* potvrdí startovní programy
* kontrolní invalidní zkratky
* kontrolní invalidní souborová spojení
* kontrolní invalidní startovní položky v menu
* vymazat prázdný registr zaklínovává
* kontroluje systém služby
* modrá obrazovka
* řidičské chyby
* systém havaruje
* úkolový manažer Související
* největší registrační problémy
* organizují rychlejší startovní programy
* fixní zpráva
* Auto - Backup & úplná záloha
* ignoruje seznam
* počítačový management
* Windows update
* systémové nemovitosti
* ovládací panel
* disk Defragmenter
* disk vyčištění
* místní bezpečnostní nastavení
* místní uživatelé a skupiny
* seskupí politický editor
* bezpečnostní centrum
* přístrojový manažer
* událost pohled
* řízení disku
* kontrolní monitor
* dodatečný/odstraňovací manažer
* BHO Manager
* internetové volby
* plánovač
* nákladové Windows rychlejší
* provozované aplikace hladce
* znovu získat více místa na disku
* výkonné skenování
* automatické aktualizace
* neomezená volná technická podpora
Poznamenávam, že tento soft je fakt velice kvalitný............. :) :) :)
 Predmet príspevku: Re: Registry Winner v4.3.2.20
PoslaťNapísal: Str 25. Feb 2009 11:19:19
pista len aby to neprecistilo regedit tak ze nenabehnu okna vedsinou sa to tak stava inak ja pouzivam system mechnik
PoslaťNapísal: Str 25. Feb 2009 15:27:31
Dr.Thrax píše:
Hellou - !!!
Kámo viem na čo myslíš, ale u tohto softu to nehrozí mám to odskušané a mimochodom pred každým spustením u akých kolvek programov predsa samotné programy sú už tak inteligentné, že uložia sami od seba komplet backup-záloju v prípade nepredvídaných problémov, ktoré sa potom dajú bezproblémovo obnovit..
PoslaťNapísal: Uto 27. Okt 2009 20:19:08
hmmmm neplatný link :(
