Aktuálny čas je Štv 01. Okt 2026 23:11:05
 Golden Records Vinyl to CD Converter v1.30
 Predmet príspevku: Golden Records Vinyl to CD Converter v1.30
PoslaťNapísal: Uto 24. Feb 2009 14:14:15
Convert vinyl records or cassette tapes to CD, wav or mp3 files Golden Records is software that helps you to convert your vinyl LP records, audio tapes or cassettes to CD or to wav or mp3 files using your computer.
It is designed specifically with records and cassettes in mind and has been developed to make the conversion process from vinyl to CD as easy and intuitive as possible. Just install the software and follow the step-by-step wizard. It also includes a number of audio restoration tools that can be automatically applied to the vinyl or cassette that is being converted as it is being saved to a wav or mp3 file.
Features
* Convert audio from vinyl LP records and audio cassette tapes into Wave/MP3 format or burn straight to CD.
* Simple intuitive wizard takes you step-by-step through the vinyl to CD conversion process.
* Comes with a full set of audio restoration tools to clean up damaged audio.
* Set "floor noise" to detect silence and automatically split tracks.
* Includes full feature CD burner to record CDs after the cassette, lp ripper or vinyl to cd wizard runs.
* Encodes into mp3 or wave files with the ability to add mp3 ID tags to converted files.
* Automatically normalizes recordings when converting your tapes or vinyl to CD.
* Automatically applies dc offset correction recordings.
* Click / pop elimination when recording from vinyl records.
* Automatic hiss and noise reduction.
* Automatic 'phono' RIAA eq correction (if your old record player does not have a preamplifier).
* Can convert 78 RPM records playing on a 45 RPM player.
Typical Applications
* Protect and convert rare vinyl EPs and LPs to CD
* Restoration of damaged tracks and albums
* Move albums from vinyl to a computer for cataloging
* Convert vinyl to mp3 for listening on portable devices
* Update cassette tapes to mp3 or CD
* Digitize any analog audio to mp3
USA,Canada, EU and Russia
Pøemìnit vinylové záznamy èi kazetové pásky k CD, wav èi mp3 soubory Golden Records je software který pomáhá Vám pøemìnit vaše vinylové LP záznamy, magnetofonové pásky èi kazety k CD èi wav èi mp3 souborùm používání vašeho poèítaèe.
To je navržené výslovnì se záznamy a kazetami na mysli a byla vyvinutá aby udìlat konverzní proces z vinylu k CD tak snadný a intuitivní jak je to možné. Jen instalujte software a následujte krok za krokem mág. To také zahrnuje øadu zvukových nástrojù obnovení které mùže je automaticky aplikována na vinyl èi kazetu která je konvertorovaná jak ta je být ušetøená k wav èi mp3 souboru.
Rysy
* konvertita zvukový z vinylových LP záznamù a zvukových kazetových pásek do Wave/MP3 formátu èi spáleniny pøímo k CD.
* jednoduchý intuitivní mág bere vy krok za krokem skrz vinyl k CD konverznímu procesu.
* jde s plnou sadou zvukových nástrojù obnovení k tomu, aby vyèistilo poškodilo audio.
* nastavil "podlahový hluk" zjistit ticho a automaticky rozštìpené dráhy.
* zahrnuje plný hlavní CD hoøák k tomu, aby zaznamenal CDS po kazetì, lp trhací stroj èi vinyl k cd mágovi bìží.
* kódovací tabulky do mp3 èi vlnových souborù se schopností k tomu, aby pøidala mp3 ID pøipevní ke konvertorovaným souborùm.
* automaticky standardizuje nahrávky pøi pøevádìní vašeho pásek èi vinylu k CD.
* automaticky žádá dc vyrovnané korekèní nahrávky.
* kliknutí / vytøeštit vylouèení pøi nahrávání z vinylových záznamù.
* automatické sykot a snížení hluku.
* automatická fonon ' RIAA eq korekce (jestli váš starý gramofon nemá pøedzesilovaè).
* mùže pøemìnit 78 RPM záznamy hraní na 45 RPM hráèi.
Typické aplikace
* ochrana a pøemìní vzácný vinylový EPS a LPS CD
* obnovení z poškozených dráh a albu
* pohybová alba z vinylu k poèítaèi pro katalog
* pøemìnit vinyl k mp3 pro poslouchání na pøenosných zaøízeních
* nové kazetové pásky k mp3 èi CD
* digitalizovat nìjaký /každý /žádný analogový zvukový mp3
USA,Kanada, EU a Rusko
