Aktuálny čas je Str 21. Okt 2026 4:14:37
 MultiTranse 5.0.2
 Predmet príspevku: MultiTranse 5.0.2
PoslaťNapísal: Sob 21. Feb 2009 14:33:11
MultiTranse - program, which uses free on-line resources, for the transfer of: English, Arab, Chinese, Dutch, Danish, Finnish, German, Spanish, Italian, Russian, Polish, Norwegian, Korean, Czech, Japanese. MultiTranse can translate the individual words, small phrases, proposals or texts, but not more than 6000 symbols at once. MultiTranse works with the texts in the size Of unicode and is capable with the retention of recoding Unicode text into any ANSI
coding and vice versa. If necessary type is not revealed on the computer of user, program will propose to load it from the Internet. Program has Russian interface. For the transfer to program is required the Internet- connection. Program has status of shareware, you can use program during 20 days after the first starting.
Basic possibilities:
- The possibility of transfer in the presence the Internet the connection of English, Arab, Chinese, Finnish, Swedish, Dutch,
Norwegian. German, Polish, Spanish, Czech, Italian, Russian, Korean, Japanese
- 100% of yunikod the compatability
- Program can recode yunikod text in ANSI the size of any coding and vice versa
- The automatic installation of type
- If program does not find type for the installation, then it proposes to load appropriate type from the Internet
- The possibility to preserve the translated text
- It works under all versions Windows, including Windows Of vista!
MultiTranse - program, který užívá volné on - line zdroje, pro transfer : Angličtina, Arab, čínský, nizozemský, dánský, finský, německý, španělský, italský, ruský, leští, norský, korejský, Čech, japonský. MultiTranse může přeložit individuální slova, malé fráze, návrhy či texty, ale ne víc než 6000 symboly najednou. MultiTranse pracuje s texty ve velikosti Unicode a je schopný se zadržením překódováni Unicode textu do nějakého /každého /žádného ANSI
kódování a naopak. Bude-li to nezbytné typ není odhalený na počítači uživatele, program bude navrhovat naložit to z Internetu. Program má ruské rozhraní. Pro transfer programu je požadovaný Internet - spojení. Program má status sharewaru, vy můžete použít program během 20 dnů po prvním začínání.
Základní možnosti:
- možnost transferu v přítomnosti Internetu spojení angličtiny, Araba, Číňanů, finštiny, švédštiny, nizozemštiny,
Norština. Němčina, polský, španělský, český, italský, ruský, korejský, Japonec
- 100% yunikod kompatibility
- programu může rekodér yunikod text v ANSI velikosti nějakého /každého /žádného kódování a naopak
- automatická instalace typu
- jestli program nenajde typ pro instalaci, pak to navrhuje naložit vhodný typ z Internetu
- možnosti uchovat přeložený text
- to pracuje pod všemi verzemi Windows, včetně Windows z výhledu!
Postup ako si to správne cracknut...........!!!
1.Nainštaluješ, ale nespustíš
2.Prekopíruješ patch do adresára nainštalovaného programu MultiTranse
3.Klik na patch a klik na crack v okne
4.Otvoríš program a klik na help a s menu si vyberes about
5.Klikneš na registrace a do otvoreného reg. okna napíšeš bársjaké meno a do pola požadujuceho serial hned na začiatok musíš uviesť tento znak "MLL" a potom pomlčka a hned za pomlčkou zadávaš bársjaké seriové číslo v tomto poradí takto "MLL-xxxxx-xxxxx-xxxxx-xxxxx" potom potvrdíš OK tým pádom okno programu sa stratí ktoré znova otvoríš a v help - aboute už budeš vydieť licencovanú verziu na to meno, ktoré si zadal pri vyplnovaní reg okna.......!!!
 Predmet príspevku: Re: MultiTranse 5.0.2
PoslaťNapísal: Str 04. Nov 2009 15:24:09
