Aktuálny čas je Ned 11. Okt 2026 13:19:28
 ViP Net Safe Disk v3.0
 Predmet príspevku: ViP Net Safe Disk v3.0
PoslaťNapísal: Pia 20. Feb 2009 15:29:50
ViPNet Safe Disk software solution is an information security system, providing safe confidential information storage and a convenient way of managing it. ViPNet Safe Disk is an easy-to-use, user-friendly software which provides transparent "on-the-fly" encryption for your notebook or desktop personal computer. Safe Disk protects user sensitive data from all kinds of e-dangers such as computer viruses, information theft or computer hijacking.
ViPNet Safe Disk Principle of operation:
In the working process, the system creates virtual encrypted containers, whose size is specified by user. The files are visible as standard disk volumes. Password authentication is performed once on the entire volume and as soon as access is granted, user can create, read, write, drag, drop and copy files to the volume just as if it were another hard drive.
Best of all, since Safe Disk appears to Windows™ as another drive letter, it is instantly compatible with almost any standard business application, word processor, spreadsheet or database program. From the main Safe Disk program window, user can easily switch to working with protected documents and continue editing them. When the disk is mounted, the data is automatically encrypted and decrypted, when the user writes or reads this data respectively. When the disk is unmounted, either manually or by logging out of Windows, the secure data it contains becomes completely unreadable and undetectable by the operating system. In case of urgent disconnection or confidential information liquidation Safe Disk conceals all the signs that may reveal user actions, even Safe Disk's icon disappears from the system tray.
ViPNet Safe Disk Features:
- ViPNet Safe Disk utilizes AES and GOST encryption algorithms with a key length - 256 bits;
- Fair-sized container creation is limited only by the File System capacity;
- Danger mode for containers urgent disconnection and Safe Disk program emergency quitting;
- Extreme Danger mode for containers destruction with no possibility to restore their contents;
- Possibility to connect containers for read only;
- Automatic connection of selected containers after logon to ViPNet Safe Disk;
- Automatic disconnection of containers after specified period of user inactivity;
- Automatic disconnection of containers after logout from ViPNet Safe Disk;
- One of the three protection types can be used to access to container: password protection, protection keys storage in a special Key file, Tokens;
- The system is invisible for a PC user: while non-activated, the system cannot be seen (only connected device of data storage (Reader, for example) can show presence of the system);
- When requested for real password, use the one for "under control" mode. The password of the given mode allows to conceal the presence of any confidential information when concealing the presence of the very system is impossible;
- In case of hard disk corruption, operating system reinstallation, or computer viruses attack, the access to the sensitive data can be restored by means of Safe Disk program with no risk for the data safety;
- Safe Disk's Configuration Recovery feature allows rolling back to the moment when undesirable changes to sensitive data have not been made;
- Wiping utility supplied with ViPNet Safe Disk reliably erases sensitive data from user's computer leaving malefactor no chance to restore it even if the data was deleted by means of the standard operating system tools (not by means of the Safe Disk program);
- Data transportation from one PC to another is safe and secure with ViPNet Safe Disk: it is accomplished with container export and then import from export file;
- Multi user working with a program is supported;
- Event log is kept to track user actions;
- Program's interface is comprehensible and smart - it excludes the possibility of destructive actions from a beginner user.
ViPNet Safe Disk softwarové řešení je informační bezpečnostní systém, poskytující bezpečnému důvěrnému informaci skladu a vhodný způsob ovládání to. ViPNet Safe Disk je snadno použitelný, uživatelsky přívětivý software který poskytuje transparentní "za letu" šifrování pro váš zápisník či desktop osobní počítač. Bezpečný Disk chrání uživatelská citlivá data ze všech druhů e-nebezpečí jako počítačové viry, informační krádež či počítač únos.
ViPNet Safe Disk princip činnosti:
V práci proces, systém vytváří virtuální zašifrované nádoby, jehož velikost je specifikovaná uživatelem. Soubory jsou viditelné jak standardní svazky disků. Heslová legalizace je vykonaná jednou na celém hlasitosti a jakmile přístupu je udělený, uživatel může vytvořit, čtený, psát, táhnout, snížit a kopíruje soubory do hlasitosti právě tak kdyby to byl další pevný disk.
Nejlepší ze všech, od Safe Disku zdá se, že Windows™ jak další písmeno disku, to je okamžitě slučitelný s téměř každý standardní obchodní aplikací, textovým procesorem, tabulkovým procesorem či databázovým programem. Z hlavního Safe Disku programového okna, uživatel může snadno přejít na pracování s chráněnými dokumenty a pokračovat s úpravou je. Kdy disk je namontovaný, data je automaticky zašifrovaná a rozkódovaný, kdy uživatel píše či čte tyto data v tomto pořadí. Kdy disk je nikoliv na koni, buď ručně či odhlášením Windows, bezpečná data to obsahuje stává se úplně nečitelný a nezjistitelný operačním systémem. V případě naléhavého odpojení či důvěrného informace likvidace Safe Disku ukryje všechny znaky které mohly odhalit uživatelské akce, dokonce Safe Disk- ovo ikonu zmizí ze systémového podnosu.
ViPNet bezpečný disk uvádí:
- ViPNet Safe Disk zužitkuje AES a GOST šifrovací algoritmy s délkou klíči - 256 kousky;
- dost veliké nádoba vytvoření je omezené jen File výkonností sítěmi;
- nebezpečný mód pro nádoby naléhavé odpojení a Safe Disk programové záchranné opuštění;
- extrémní nebezpečný mód pro nádoby ničení se žádnou možností obnovit jejich obsah;
- možnost spojit nádoby jen pro na čtení;
- automatické spojení z vybraných nádob po navázání k ViPNet Safe Disku;
- automatické odpojení nádob po specifikované době uživatelské nečinnosti;
- automatické odpojení nádob po odhlášení ze systému z ViPNet Safe Disku;
- jeden ze tří druhy ochrany mohou být užívaný pro zpřístupnit nádobě: ochrana heslem, ochranný klíče sklad v speciální klávese registruje, znaky;
- systém je neviditelný pro PC uživatel: zatímco ne-aktivoval, systém nemůže být viděný (jen spojené zařízení ukládání dat do paměti (čtenář, například) může ukázat přítomnost systému);
- kdy žádost o skutečné heslo, užívat jeden pro "pod kontrolou" mód. Heslo daného módu dovoluje ukrýt přítomnost nějaké /každé /žádné důvěrné informace při ukrývání přítomnosti velice systému je nemožný;
- v případě harddisku zkaženosti, operační systémový znovu nainstaluje, či počítačový viry napadnou, přístup k citlivým datům může být obnovený přes Safe Disk program se žádným rizikem pro datové bezpečí;
- bezpečný disk- ovo konfigurační obnovovací rys dovoluje válející zpět do okamžiku kdy nevhodné změny citlivým datům nebyly udělané;
- stírací utilita dodaný s ViPNet Safe Diskem spolehlivě vymaže citlivá data z uživatelské počítače odcházející zločince žádné šance na to obnovit to dokonce když data byla zrušené přes standardní operační systémové nástroje (ne přes Safe Disk program);
- datová doprava z jednoho PC další je bezpečná a bezpečný s ViPNet Safe Diskem: to je udělaný s nádobou exportem a potom importovat z exportního souboru;
- multi - uživatel pracování s programem je podporované;
- deník událostí je držený k tomu, aby sledoval uživatelské akce;
- programové rozhraní je srozumitelné a chytrý - to vylučuje možnost destruktivních akcí ze začátečnického uživatele.
 Predmet príspevku: Re: ViP Net Safe Disk v3.0
PoslaťNapísal: Str 04. Nov 2009 15:30:44
