Aktuálny čas je Sob 25. Júl 2026 8:22:56
 DVD-Cloner VI 6.00-Najnovšia verzia
 Predmet príspevku: DVD-Cloner VI 6.00-Najnovšia verzia
PoslaťNapísal: Pia 13. Mar 2009 11:24:29
DVD-Cloner is excellent DVD copy software that makes quality DVD backups to DVD-R/RW super easily. DVD-Cloner makes backing up your copy-protected DVD movies simple. With your DVD burner and DVD Cloner software, you pop in the DVD you want to copy in your DVD-ROM and a blank DVD in your DVD Burner and click the button to start the DVD burning process. You can clone your DVD entirely within 2-3 hours, in the same quality as the original. The cloned DVD can be played in any compatible DVD Player. Plus, DVD Cloner is one of the few DVD backup software titles that has a built-in CSS/DVD Ripper.
The new burning engine can make perfect 1:1 copy. It can intelligently identify the disc type and display relevant copy modes on the interface for you to select. Supports for the backup of Blu-ray / HD DVDs. You do not need to download a separate program like DVD43 or AnyDVD. Works on 2000/XP/Vista.
DVD-CLONER Features:
Perfect 1:1 DVD Copy
- Brand-new burning engine, Perfect 1:1 DVD Copy - brings you an excellent backup experience. The copied discs will remain 100% same to the original, no quality loss! New
- Makes perfectly audio-and - video synchronous copies! New
- Copies DVD movie to ISO or NRG file and backs up DVD movie to hard disk drive (FAT32, NTFS supported), burns ISO and NRG files to DVDs. New
- Copies CSS-encrypted, Region- protected and Sony ARCCOS protected DVD movies.
Customized Copy
- Intelligent Identification Tech - intelligently identifies the disc type and displays relevant copy modes on the interface. New
- Copies any chapter you like with DVD-Cloner V New
- Now you can define the number of discs to be burned - great for batch copying. New
- DVD-5 to DVD-5 copy
- Movie only copy - copies main movie only with extras and special features omitted
- Adjusting the compression rate from 10% to 100% - saves your disc space
- Splits DVD-9 into two DVD-5s
- DVD-9 to DVD-9 copy
- Burns DVDs from hard drive to blank DVD-r/rw
- Supports for episodic DVD copying - You can copy your preferred chapters.
Other features
- With a third party Blu-Ray/HD DVD Copy Helper, you can backup HD-DVD and Blu-ray movies to your hard drive and watch them with Cyberlink Powerdvd or Windvd as you like! (You can download and install the Blu-Ray/HD DVD Copy Helper at http://www.copyhddvd.net)
- Trial version - copies a whole DVD movie for free! New
- Just one click and you can become a DVD backup expert!
- High Compatibility - supports for PAL, NTSC, DVD+-R/RW and most DVD players.
- High burning speed.
- Multi - languages
What'new in DVD-Cloner V:
* Brand-new burning engine, perfect 1:1 DVD Copy
* Much easier to use - intelligently identifies the disc type and displays relevant copy modes on the interface for you to select!
* Copies any chapter you like
* You can define the number of discs to be burned.
* Copies DVD movie to ISO or NRG file and backs up DVD movie to hard disk drive (FAT32, NTFS supported), burns ISO and NRG files to DVDs.
* Supports for the backup of Blu-Ray/HD DVDs
* Trial version: copies a whole DVD movie for free!
* Smart Help Tech - Intelligently detects errors during the copying and prompts you how to deal with them.
Changes in DVD-Cloner 6.00 (Nov 21, 2008):
* Enhanced burning engine, fast and stable burn
* Verifies data after the burning, ensuring a perfect 1:1 copy
* Supports the backup of latest Blu-ray movies. Burns Blu-ray movies to harddisk drive.
* Supports the backup of ISO, NRG files.
* Burns two DVD movies onto one DVD-R/RW DL with customized menu.
* With “Split DVD-9 to two DVD-5s” copy mode, the movie title and menu of source DVD will be copied to the second disc for your convenience.
* Improved the chapter copy function, great for episodic DVD copying
* Brand-new user interface. Step by step direction makes the burning simple.
DVD-Cloner je vynikající DVD kopírovací software který dělá kvalitní DVD zálohování k DVD-R/RW extra snadno. DVD-Cloner dělá zálohování vašich kopírovacích-chráněných DVD filmů jednoduchých. S vaším VYPALOVAČKOU DVD a DVD Cloner softvérem, vy stavíte se DVD vy chcete kopírovat ve váš DVD-ROM a prázdný DVD ve vaší VYPALOVAČCE DVD a kliknout na knoflík k tomu, aby začal DVD hořící proces. Vy můžete klon váš DVD zcela během 2-3 hodin, v stejné kvalitě jak originál. Klonovaný DVD může být hraný v nějakém /každém /žádném kompatibilním DVD PŘEHRÁVAČI. Plus, DVD Cloner je jeden z mála DVD zálohovacích softéru titulů které má zabudované CSS/DVD Ripper.
Nový hořící motor může udělat perfektní 1:1 kopíruje. To může inteligentně identifikovat typ disku a zobrazit významné kopírovací režimy na rozhraní pro vás vybrat. Podpory pro zálohování Blu - ray / HD DVDS. Vy nemusíte stáhnout separátní program jako DVD43 či AnyDVD. Práce na 2000/XP/Vista.
Zdokonalte 1:1 DVD Copy
- zbrusu nový hořící motor, perfektní 1:1 DVD Copy - přináší vám vynikající záložní zkušenost. Kopírované disky zůstanou 100% stejný do originálu, žádné kvalitní ztráty! Nový
- dělá dokonale audio-a - video synchronní kopie! Nový
- kopie DVD film k ISO či NRG registruje a zálohuje DVD film k harddisku (FAT32, NTFS podporoval), vypálí ISO a NRG soubory k DVDS. Nové
- kopie CSS-zašifrovaný, Region - chráněné a Sony ARCCOS chráněné DVD filmy.
Zákaznicky přizpůsobená Copy
- inteligentní technika identifikace - inteligentně identifikuje typ disku a zobrazuje významné kopírovací režimy na rozhraní. Nová
- kopie nějaká /každá /žádná kapitola, kterou vy máte rád s DVD-CLONER V noví
- nyní vy můžete definovat počet disků který má být spálené - ohromné pro dávku kopírování. Nový
- DVD-5 DVD-5 kopii
- filmu jen kopíruje - kopie hlavní film jen s něco navíc a zvláštnostmi vynechaným
- regulováním kompresního poměru z 10% k 100% - chrání vaše disková prostor
- rozštěpení DVD-9 do dvou DVD-5S
- DVD-9 DVD-9 kopii
- spáleninám DVDS z pevného disku k tomu, aby předkoval DVD-R/rw
- podpory pro epizodické DVD kopírování - vy můžete kopírovat vaše preferované kapitoly.
Jiné rysy
- s třetí osobou Blu - Ray/HD DVD Copy Helper, vy můžete zálohovat HD-DVD a Blu - ray filmy vašemu pevnému disku a sledujete je s Cyberlink Powerdvd či Windvd jak chce! (vy můžete stáhnout a instalovat Blu - Ray/HD DVD Copy Helper v http://www.copyhddvd.síť)
- zkušební verze - kopie celý DVD film zdarma! Nové
- jediné kliknutí a vy se můžete stát DV
D záložním expertem!
- vysoká kompatibilita - podporuje pro PAL, NTSC, DVD+ -R/RW a většina DVD PŘEHRÁVAČŮ.
- vysoká hořící rychlost.
- multi - - jazyky
What'new v DVD-CLONER V:
* zbrusu nový hořící motor, zdokonalte 1:1 DVD kopírovat
* moc snadno použitelný - inteligentně identifikuje typ disku a zobrazuje významné kopírovací režimy na rozhraní pro vás vybrat!
* kopie nějaká /každá /žádná kapitola, kterou vy máte rád
* vy můžete definovat počet disků který má být spálené.
* kopie DVD film k ISO či NRG registruje a zálohuje DVD film k harddisku (FAT32, NTFS podporoval), vypálí ISO a NRG soubory k DVDS.
* podpory pro zálohování Blu - Ray/HD DVDS
* zkušební verze: kopie celý DVD film zdarma!
* chytrá pomocná technika - inteligentně zjistí chyby během kopírování a vybízí, že vás jak jednat s nimi.
Změny v DVD-CLONER 6.00 (listopad 21, 2008):
* zvětšený hořící motor, rychlá a stabilní spálenina
* ověřte data po hoření, zajištění perfektního 1:1 kopíruje
* podpory zálohování posledních Blu - ray filmů. Popáleninové Blu - ray filmy k mechanice pevného disku.
* podpory zálohování ISO, NRG souborů.
* vypalte dva DVD filmy na jeden DVD-R/RW DL se zákaznicky přizpůsobeným menu.
* s "rozštěpeným DVD-9 k dvěma DVD-5s" kopírovat mód, filmové titul a menu zdrojový DVD bude kopírovaný k druhému disku pro vaši potřebu.
* zlepšená kapitola kopie funguje, ohromný pro epizodické DVD kopírování
* zbrusu nové uživatelské rozhraní. Krok za krokem směr dělá hořící jednoduchý.
