Aktuálny čas je Pon 26. Okt 2026 7:24:55
 AnyDVDAnyDVD HD v6.5.2.6 Final
 Predmet príspevku: AnyDVDAnyDVD HD v6.5.2.6 Final
PoslaťNapísal: Sob 07. Mar 2009 11:57:26
AnyDVD is a driver, which descrambles DVD-Movies automatically in the background. This DVD appears unprotected and region code free for all applications and the Windows operating system as well. With AnyDVD's help copy tools like CloneDVD, Pinnacle Instant Copy, InterVideo DVD-Copy, etc. are able to copy CSS protected Movies. You can remove the RPC region code, thereby making the movie region free and viewable on any DVD player and with any DVD player software. With the help of AnyDVD you can watch movies with non matching region codes with every DVD Player Software you like!
AnyDVD is capable of removing unwanted movie features, including subtitles and prohibition messages such as copyright and FBI warnings. It also allows you to launch an external application whenever you insert or remove a disc, or prevent 'PC-friendly'software from automatically launching when you insert a video DVD. AnyDVD decrypts not just DVDs: AnyDVD allows you also to play, copy and rip protected Audio CDs!
Decryption is not all that AnyDVD offers. You can control the drive speed of your DVD drive, allowing you to reduce the noise level when watching movies on your PC. You can even adjust the display frequency of your monitor for both NTSC and PAL displays.
Features of AnyDVD:
• Works automatically in the background
• Removes encryption (CSS) and region code (RPC) from DVDs
• Removes analogue copy protection (Macrovision)
• Removes features such as forced subtitles and warnings
• Decrypts without the need to save the data onto your hard-disk
• Decrypts 'on the fly'
• Prevents automatic launching of 'PC-friendly' software on video DVDs
• Allows adjustment of your monitor refresh rate for both NTSC and PAL monitors
• Allows execution of external programs on disc insertion and removal
• Allows speed control of your DVD drives
• Compatible with all DVD media
• Works with all DVD-drives, regardless of region code
• Works with all DVD copying, such as CloneDVD, and all DVD player software
• Works transparently for the operating system: DVDs can be shared over the network and copied with the command prompt or with Windows Explorer, etc.
• Proven to be stable and fast and does not require an ASPI driver
• Features AnyCDDA: play, copy and rip protected audio CDs
AnyDVD HD comes with same functionality as AnyDVD, but with additional features for full HD-DVD (High Definition DVD) support, including decryption of HD-DVD movie discs.
Allows you to watch movies over a digital display connection, without HDCP compliant graphics card and HDCP compliant display. No need to buy an expensive monitor. Sweet!
Playback your discs on your PC with PowerDVD Ultra, which otherwise do not run (titles released by Studio Canal, The Weinstein Company, Kinowelt, Optimum Releasing).
AnyDVD HD is the "must have" utility for the serious home theater enthusiast using a media center / home theater PC.
Another amazing feature of AnyDVD HD is "magic file replacement ā„¢". Remaster any commercial movie disc using simple XML scripts. These scripts will "magically" replace the files on the physical disc. You can customize discs as you like without even making a copy to harddisk!
AnyDVD comes with a UDF 2.5 file ripper, no need to install 3rd party UDF 2.5 filesystem under Windows XP.
Features of AnyDVD HD:
• Same features as regular AnyDVD
• Removes encryption (AACS) from HD-DVDs
• watch movies over digital display connection, without HDCP compliant graphics card and HDCP compliant display.
• playback of discs on the PC with PowerDVD Ultra, which otherwise do not run.
• Removes user prohibitions, you can select the language and subtitle track without going through the disc's menu.
• Removes parental restrictions.
• Allows you to remove or skip Studio Logos and warning messages.
• With "magic file replacement ā„¢" you can remaster any commercial movie disc using simple XML scripts.
• The "must have" utility for the serious home theater enthusiast using a media center / home theater PC.
• Includes a UDF 2.5 file ripper, no need to install 3rd party UDF 2.5 filesystem under Windows XP.
Features Blu-Ray:
• Removes encryption (AACS) from Blu-Ray DVDs
• Removes region codes from Blu-Ray DVDs
WAHTS NEW: 6.5.2.6 2009 03 06
- New (DVD): Added workaround for a weird authoring error found on some
DVDs, e.g. "The Closet", UK
- Change: Autoplay is no longer disabled while settings dialog is shown
- Fix (Blu-ray): Message "MFR: File is too big!" with some discs
- Fix (Blu-ray): Playback issues with Panasonic Blu-ray players
- Fix: Security vulnerability of the driver interface
- Some minor fixes and improvements
- Updated languages
AnyDVD je řidič, který dekóduje DVD-Movies automaticky v pozadí. Toto DVD jeví se nechráněný a region kód přístupný všem aplikace a windowsovský operační systém také. S AnyDVD- ovo pomocí kopíruje nástroje jako CloneDVD, instantní kopie vrcholu, InterVideo DVD-kopie, a tak dále jsou schopni kopírovat CSS chráněný Movies. Vy můžete odstranit RPC územní kód, tím dělání filmového regionu bezplatného a viditelný na nějakém /každém /žádném DVD přehrávači a s nějakým /každým /žádným DVD hráčským softvérem. Za pomoci AnyDVD vy můžete sledovat filmy s ne - odpovídajícími region kódy s každým DVD Player Softwareem, které vy máte rád!
AnyDVD je schopný odstranění nechtěných filmových rysů, včetně titulků a zpráv zákazu jako copyright a FBI varování. To také dovoluje vám spustit externí aplikaci kdykoli vy vložíte či odstranit disk, či zabrání ' PC-friendly'software z automaticky spuštění kdy vy vložíte video DVD. AnyDVD rozkóduje ne jen DVD: AnyDVD také dovoluje vám hrát, kopírovat a vytrhnout chráněný Audio CDs!
Rozluštění není všechno co AnyDVD nabízí. Vy můžete ovládat rychlost pohonu vašeho DVD pohonu, dovolující vás redukovat hladinu hluku při dívající se filmy na vašem PC. Vy můžete dokonce nastavit displejovou četnost vašeho monitoru pro oba NTSC a PAL displeje.
Rysy AnyDVD:
• Práce automaticky v pozadích
• Odstranění šifrování (CSS) a regionu kóduje (RPC) z DVDs
• Odstranění analogická ochrana proti kopírování (Macrovision)
• Odstranění uvádí jako přinucená titulky a varování
• Rozkóduje bez potřeby chránit data na váš brod-disk
• Rozkóduje ' za letu '
• Předchází automatickému spuštění ' PC-friendly ' softéru na video DVDs
• Dovoluje úpravu vašeho monitoru obnovovacího kmitočtu pro oba NTSC a PAL monitory
• Dovoluje výkon vnějších programů na diskovém vložení a vyjmutí
• Dovoluje rychlostní kontrolu nad vašimi DVD pohony
• Kompatibilní se všemi DVD médii
• Práce se všemi DVD-pohony, bez ohledu na územní kód
• Práce se všemi DVD kopírováním, jako CloneDVD, a všechno DVD hráčský software
• Práce průhledně pro operační systém: DVDS může být sdílený přes síť a kopírovaný s příkazovým řádkem či s windowsovský Explorer, a tak dále
• Prokázaný k tomu, aby byl stabilní a postit se a nevyžaduje ASPI řidiče
• Rysy AnyCDDA: hrajte, kopie a vytrhnout chráněný zvukový CDs
AnyDVD HD jde se stejnou funkčností jak AnyDVD, ale s přidanými vlastnostmi pro plnou HD-DVD (vysoká definiční DVD) podpora, včetně rozluštění HD-DVD filmových disků.
Dovoluje vám dohlížet na filmy digitální displej spojení, bez HDCP vyhovujícího grafického karty a HDCP vyhovujícího displeje. Není třeba koupit drahý monitor. Sladký!
Playback vaše disky na vašem PC s PowerDVD Ultra, které jinak neběží (tituly uvolněné od Studio Canal, Weinstein Company, Kinowelt, optimální uvolnění).
AnyDVD HD je "musí mít" utilitu pro vážné domácí divadelní nadšence používání multimediální centrály / domácí divadelní PC.
Další úžasný rys AnyDVD HD je "kouzelné souborové nahrazení āa€˛Ac". Remaster nějaký /každý /žádný komerční filmový disk používání jednoduchých XML skriptů. Tyto skripty "kouzelně" vymění soubory na fyzickém disku. Vy můžete přizpůsobit disky jak chcete dokonce bez dělání kopie pevnému disku!
AnyDVD jde s UDF 2.5 registruje trhací stroj, není třeba instalovat třetí stranu UDF 2.5 filesystem pod windowsovský XP.
Rysy AnyDVD HD:
• Stejné rysy jak pravidelný AnyDVD
• Odstranění šifrování (AACS) z HD-DVDs
• dohlížet na filmy digitální displej spojení, bez HDCP vyhovující grafické karty a HDCP vyhovujícího displeje.
• playback disků na PC s PowerDVD Ultra, které jinak neběží.
• Odstranění uživatelské zákazy, vy můžete vybrat jazyk a dialogovou titulek dráhu bez procházíte diskovým menu.
• Odstranění rodičovská omezení.
• Dovoluje vám odstranit či skákat Studio Logos a výstražné zprávy.
• S "kouzelným souborovým nahrazením āa€˛Ac" vy můžete vyměnit stěžně nějaký /každý /žádný komerční film diskové používání jednoduchých XML skriptů.
• "musí mít" utilitu pro vážného domácího divadelního nadšence používání multimediální centrály / domácí divadelní PC.
• Zahrnuje UDF 2.5 registruje trhací stroj, není třeba instalovat třetí stranu UDF 2.5 filesystem pod windowsovský XP.
Rysy Blu-Ray:
• Odstranění šifrování (AACS) z Blu - Ray DVDs
• Odstranění region kóduje z Blu - Ray DVDs
• "muset mít" utilitu pro vážného domácího divadelního nadšence používání multimediální centrály / domácí divadelní PC.
WAHTS NOVÝ: 6.5.2.6 2009 03 06- nový (DVD): Přidaný workaround pro podivnou vývojovou chybu nalezenou na nějaký
DVDS, například "Přístěnek", , UK- změna: Autoplay již není vyřazený zatímco dialog nastavení je ukázaný- upevnit (Blu- paprsek): Zpráva "MFR: Soubor je příliš velký!" s nějakými disky- upevní (Blu-paprsek): Reprodukční končí s Panasonicem Blu - ray hráči- opravou: Bezpečnostní zranitelnost řidičského rozhraní- nějaký menší upevní a zlepšení- aktualizované jazyky
