Aktuálny čas je Str 29. Júl 2026 14:02:59
 Movie DVD Ripper 6.0.1
 Predmet príspevku: Movie DVD Ripper 6.0.1
PoslaťNapísal: Sob 07. Mar 2009 11:55:57
Powerful DVD ripping - Movie DVD ripper is powerful DVD ripper, DVD ripping software to rip DVD movie to almost all popular video/audio formats like DVD to MPEG, AVI, DivX, WMV, WMA, ASF, VCD, SVCD etc easily with high DVD ripping speed.
# Top-quality, easy-to-work-with DVD ripping software
Compared with other DVD ripping software, Movie DVD Ripper has more settings easier than ever to customize. Whether you are a veteran or beginner, you will feel it's developed for you!
# Excellent image and sound quality
The DVD ripping software provides you excellent image and luxuriant sound in smaller file size just within a few clicks. Easy and fast in DVD ripping!
# Easy to learn and easy to use
There's practically no learning curve with Movie DVD Ripper. You can be up and running in minutes.
Movie DVD Ripper is powerful DVD ripping software which helps you rip DVD to VCD, DivX, AVI, MPEG with super fast DVD ripping speed and excellent quality.
Key Features
Suit for both veterans and beginners
If you are a veteran, the DVD ripper has so many options for you to set; if it's the first time you rip DVD movie, just ignore these options, and use default settings customized for DVD ripping to rip DVD directly in a few clicks with DVD Ripper.
Automatically check your CPU type
Movie DVD Ripper can check your CPU type automatically, fully use your CPU to rip DVD in the best DVD ripping speed.
What's New in Version 3?
Powerful features
Compared with other DVD ripping software, it has more settings you can customize, such as rip DVD by custom file size, split output file to fit your CD-R, rip DVD's any segment, select target subtitle and audio track, etc. Movie DVD Ripper provides you brand-new experience in DVD ripping, rip DVD to VCD, DVD to DivX, DVD to AVI with its super fast ripping speed and wonderful output quality within a few clicks.
Easy to use
Easy to use and super fast DVD ripping speed, just a few clicks to rip DVD to VCD, DivX, AVI, MPEG, etc! Free download Movie DVD Ripper to have a wonderful experience now!
Provide >200% ripping speed
Fully support Intel® Pentium D Dual-Core Processor and AMD Athlon™ 64 X 2 Dual-Core Processor. Auto-detects your CPU. The ripping will be done at the best DVD ripping speed
Buy Now!
Support preview
You can preview the DVD movie before DVD ripping started, or even watch the DVD movie at the same time when ripping DVD.
Support batch conversion
You can add more then one task when ripping the DVD.
Using Movie DVD Ripper, you will get any movie format you want with excellent image and sound quality.
System Requirements
* OS: Windows 98/Me/2000/2003/XP, Windows Vista or better
* CPU: >750MHz Intel or AMD CPU
* RAM: 64 MB RAM or above
Silné DVD trhání - filmový DVD trhací stroj je silný DVD trhací stroj, DVD trhající software k tomu, aby vytrhl DVD film téměř všem populárním video/zvukovým formátům jako DVD MPEG, AVI, DivX, WMV, WMA, ASF, VCD, SVCD atd snadno s vysoký DVD trhající rychlosti.
# prvotřídní jakost, snadný--pracovní-s DVD trhajícím softvérem
Ve srovnání s jiným DVD trhajícím softvérem, filmový DVD Ripper má více nastavení snadnějších než kdy předtím přizpůsobit. Zda vy jste veteráni či začátečníci, vy budete cítit to je vyvinutý pro vás!
# vynikající obraz a zvuková kvalita
DVD trhající software poskytuje vám vynikající obraz a bujný zvuk v menší velikosti souboru jen během několika kliknutí. Snadný a rychlý v DVD trhání!
# snadný k tomu, aby učil se / dozvěděl se a snadno použitelný
Není žádné prakticky křivka osvojování znalostí s Movie DVD Ripper. Vy můžete být vzhůru a běžící v minutách.
Filmový DVD Ripper je silný DVD trhající software který pomáhá Vám vytrhnout DVD VCD, DivX, AVI, MPEG s extra rychlý DVD trhající rychlosti a vynikající kvality.
Klíčové rysy
Oblek pro oba veteráni a začátečníci
Jestli vy jste veteráni, DVD trhací stroj má tolik voleb pro vás nastavit; jestli to je poprvé, kdy vy vytrhnete DVD film, jen ignoruje tyto volby, a užívají standardní nastavení zákaznicky přizpůsobený pro DVD trhání k tomu, aby vytrhlo DVD přímo v několika kliknutích s DVD Ripper.
Automaticky kontrolujte váš CPU typ
Filmový DVD Ripper může kontrolovat váš CPU typ automaticky, plně užívat váš CPU k tomu, aby vytrhl DVD v nejlepší DVD trhající rychlosti.
Co je nového ve verzi 3?
Silné uvádí
Ve srovnání s jiným DVD trhajícím softvérem, to má více nastavení, která vy můžete přizpůsobit, jako útržková DVD na základě velikost souboru, rozštěpil výstupní soubor k tomu, aby upravil váš CD-R, vytrhnout DVD- ovo nějakou /každou /žádnou část, vybrat cílovou dialogovou titulek a zvukovou stopu, a tak dále Filmový DVD Ripper poskytuje vám zbrusu novou zkušenost s DVD trháním, vytrhne DVD VCD, DVD do DivX, DVD AVI s jeho extra rychlou trhající rychlostí a báječné kvality výstupu během několika kliknutí.
Snadno použitelný
Snadno použitelná a extra rychlá DVD trhající chvátat, jen několik kliknout pro vytrhnout DVD VCD, DivX, AVI, MPEG, atd! Bezplatné stažení Movie DVD Ripper mít báječnou zkušenost právě teď!
Poskytovat >200% trhající chvátat
Plně podporujte Intel® Pentium D Dual - Core Processor a AMD Athlon™ 64 X 2 Dual - Core Processor. Jede autem-zjistí váš CPU. Trhání bude udělané v nejlepší DVD trhající rychlosti
Kupte právě teď!
Podpůrný náhled
Vy můžete si prohlédnout DVD film před DVD trhající jste začali, či dokonce sledovat DVD film zároveň při trhající DVD.
Podporovat konverzi dávky
Vy můžete přidat více pak jednoho úkolu při trhání DVD.
Vynikající obraz a zvuková kvalita
Používání Movie DVD Ripper, vy dostanete nějaký /každý /žádný filmový formát vy chcete s vynikajícím obrazem a zvukovou kvalitou.
Systémové požadavky
* OS: Windows 98/mě/2000/2003/XP, Windows Visty či lepší
* CPU: >750MHz Intel či AMD CPU
* RAM: 64 MB RAM či nahoře
