Aktuálny čas je Pia 24. Júl 2026 11:54:46
 SMS-it v3.6.5
 Predmet príspevku: SMS-it v3.6.5
PoslaťNapísal: Str 04. Mar 2009 11:18:53
Send SMS (Small Message Service) messages to mobile phones via PC.
SMS-it! allows you to send a short message (SMS = Short Message Service) to a mobile phone using your computer. SMS-it supports Picture messages, Caller Group Graphic, Operator Logo, Ringtones and Flash SMS. The messages can be sent through an attached modem, through an internet connection or directly through an attached mobile phone. If a mobile phone is attached to the computer (IE through the IR port), the contents of the inbox can be downloaded and stored in folders. The phonebook can also be downloaded and synchronized with SMS-it!.
- SMS-it! supports also downloading of WAP content to download polyphonic ringtones.
- Sending Picture messages, Caller Group Graphics, Operator Logos and Ringtones only work for Nokia phones. Most new phones can however now receive FlashSMS.
- Downloading and synchronizing the address book is possible on most mobile phones that can connect to a computer (either through the IR port or a cable link).
- SMS-it can also integrate with MS Outlook in order to send SMS from the control bar or to send an SMS whenever a Reminder comes up.
The user interface currently supports the following languages:
English
French
German
Hungarian
Portuguese BR
Rumanian
Russian
Swedish
How can messages be sent?
Messages can be sent either
-- Through a modem, using a dial-up SMS center
-- Through the internet, using an account with an internet SMS center
-- Through a mobile phone attached to the computer (IE attached to the IR port)
What protocols are supported?
SMS-it supports a wide range of protocols (XIO/TAP, UCP, INET, PDU) hence can be used for most of the SMS services.
How does it work?
SMS-it accesses through your modem, the internet or the mobile phone an SMSC (Short Message Service Center) and submits the message you wish to send. Then the SMSC transmits this message to the desired mobile phone.
-= Sending directly through the mobile phone =-
When you send the message through your mobile phone (attached to the computer), SMS-it will use the parameters (Sender ID, SMS center, etc) of your phone to send the message.
Sending will work the same as when sending messages from your phone, except that you type the message on your computer. Not all phone manufactures implement however a link to the computer (IR port or serial cable link).
You can send text, pictures and ringtones.
Having the mobile phone connected to the computer has the additional advantage that you can transfer data from your phone to the computer and back. IE you can synchronize your phone book and archive received SMS on your computer.
-= Sending through the modem =-
Sending the message through a modem will connect to an SMSC (SMS center) that relays your message to its destination. There are several mobile phone providers that offer this modem dial-up. The connection is to a local server (not to the internet), hence you need to chose an SMSC that is within your region. Alternatively you may select to dial a server abroad, but the communication cost will be expensive. When dialing abroad you need also to change the access number of the SMSC, to include the international dial codes
There are two different protocols supported by the SMSC, either XIO/TAP or UCP. XIO/TAP is an older protocol initially designed for pager messages. SMSCs that support this protocol will not be able to process pictures or ringtones. They can only process text messages and can not send the SenderID.
SMSCs that support the UCP protocol can send text, pictures and ringtones and support sending of the SenderID.
-= Sending through the Internet =-
SMS-it can send messages through a number of commercial gateways Those sites allow you to set up an account and buy blocks of SMS. You can then send the messages either through their web site or through our SMS-it.
Cost
The cost per SMS is more or less the same. With the mobile phone link and the modem link you pay on a per usage, while with the internet gateway you prepay blocks of messages.
Supported mobile phones
SMS-it will work with all mobile phones that come with a modem driver.
Pošlete SMS (malým zprávě službu) zprávy mobilním telefonům přes PC.
SMS-to! dovoluje vám poslat krátké zprávě (SMS = krátkou zprávu službu) k používání mobilního telefonu vašeho počítače. SMS-to podporuje Picture zprávy, volající skupinové grafické, operátorské logo, Ringtones a Flash SMS. Zprávy mohou být poslaný skrz připojený modem, skrz internetové spojení či přímo skrz připojený mobilní telefon. Jestli mobilní telefon je spojen s počítačem (IE skrz IR přístav), obsah inboxu může být stáhnutý a uložený v složkách. Telefonní seznam může také byl stáhnutý a synchronizovaný se SMS-to!.
- SMS-to! podpory také stahování WAP uspokojí stáhnout mnohohlasému ringtones.
- posílání obrazových zpráv, volající skupinová grafika, operátorský loga a Ringtones jediná práce pro Nokia telefonuje. Většina nových telefonů může nicméně nyní přijmout FlashSMS.
- stahování a synchronizačního adresáře je možné na většině mobilních telefonů které může připojit k počítači (buď skrz IR portovat či kabel spojení).
- SMS-IT může také sloučit s MS OUTLOOK k tomu, aby poslal SMS z kontroly baru či poslat SMS kdykoli Reminder přichází.
Uživatelské rozhraní aktuálně podporuje následující jazyky:
Angličtina
Francouzi
Němec
Maďarský
Portugalský BR
Rumun
Ruský
Švédský
Jak mohou zprávy byly poslané?
Zprávy mohou být poslaný buď
- - skrz modem, používání telefonního SMS středit
- - skrz internet, používání účtu u internet SMS středit
- - skrz mobilní telefon napojený na počítač (IE napojený na IR portovat)
Co protokoly jsou podporované?
SMS-to podporuje široký okruh protokolů (XIO/TAP, UCP, INET, PDU) z toho důvodu může být použitý pro většinu SMS služeb.
Jak to pracuje?
SMS-to zpřístupňuje skrz váš modem, internet či mobilní telefon SMSC (krátké zpráva servisní středisko) a předkládá zprávu, kterou vy přejete si poslat. Pak SMSC přenáší tuto zprávu k požadovanému mobilnímu telefonu.
- = posílání přímo skrz mobilní telefon = -
Kdy vy pošlete zprávu skrz váš mobilní telefon (napojený na počítač), SMS-IT bude užívat parametry ( ID odesílatele, SMS středí, atd) vašeho telefonu k tomu, aby poslal zprávu.
Posílání bude pracovat stejné jako když posílání zpráv z vašeho telefonu, až na to, že vy napíšete zprávu na vašem počítači. Ne veškeré telefon výroby realizovat nicméně spojení k počítači (IR portovat či sériové kabel spojení).
Vy můžete poslat text, obrázky a ringtones.
Mít mobilní telefon připojený k počítači má dodatečnou výhodu který můžete přenášet data z vašeho telefonu k počítači a zádům. IE vy můžete být současným váš telefonní seznam a archivovat dostal SMS na vašem počítači.
- = posílání skrz modem = -
Posílání zprávy skrz modem připojí k SMSC (SMS centru) které vystřídá vaši zprávu do jeho cíle. Je tam několik mobilu telefonních dodavatelů kteří nabízet tento modem telefonní. Spojení je k lokálnímu serveru (ne - internetu), z toho důvodu vy potřebujete vybrat SMSC který je uvnitř vašeho regionu. Alternativně můžete vybrat vytočit server v cizině, ale komunikační cena bude drahá. Při vytočit v cizině vy potřebujete také měnit přístupové množství SMSC, zahrnout mezinárodní číselníkové kódy
Tam jsou dva jiné protokoly podporovaný SMSC, buď XIO/TAP či UCP. XIO/TAP je starší protokol zpočátku určený pro pagera zprávy. SMSCS který podporovat tento protokol nebude schopných zpracovat obrázky či ringtones. Oni mohou jen zpracovat textové zprávy a nemůže poslat SenderID.
SMSCS který podporovat UCP protokol může poslat text, obrázky a ringtones a podpůrné posílání SenderID.
- = posílání skrz Internet = -
SMS-to může zpravit skrz řadu komerčních průjezdů Those míst vám dovolí nastavit účet a koupit bloky SMS. Vy můžete pak poslat zprávy buď skrz jejich webovou stránku či skrz náš SMS-to.
Cena
Cena za SMS je více nebo méně stejná. S mobilem telefonním spojením a modemem spojením vy platíte na za užívání, zatímco s internetovým průjezdem vy předplatíte bloky zpráv.
Podporované mobilní telefony
SMS-to bude pracovat se všemi mobilními telefony které přijít s modemem řidičem.
